1984 vf500f about to buy, should I do it?
Discussion in '1st & 2nd Generation 1983-1989' started by timmah1991, Mar 23, 2010.
  1. timmah1991
    timmah1991 New Member
    Chicago, IL
    Mk, about to leave to go snap a few pics and see the bike again one more time before I buy it!
    anyone else have any tips for this visit?
    #61
  2. Mobtown
    Mobtown New Member
    Baltimore, MD
    Kind of...but not really
    #62
  3. matt1986vf500f
    matt1986vf500f New Member
    Lula, Georgia, United States
    there not stock that for sure
    #63
  4. timmah1991
    Chicago, IL
    With any luck it should be printed on the rim, right?
    #64
  5. matt1986vf500f
    doubt it! the 500F2 wheels where only made for the euro market IF they are then somone has brought them over here most of the 500 wheels i've seen look like the front wheel on my bike just a different color.
    #65
  6. xwarp
    xwarp New Member
    did you get this bike? if so, are you looking for the stock wheels? i might have a rear available for a song if so.
    #66
  7. timmah1991
    Chicago, IL
    Well guys, I got the bike.
    And it is, for lack of a better word, beautiful.
    Stay tuned for my eventual "how do I fix problem X" threads!
    #67
  8. Cundalini
    Cundalini New Member
    Sacramento CA
    Well.
    It looks like a pile of crap.
    I am hoping that you enjoy your mistake.
    #68
  9. Cundalini
    Sacramento CA
    NAAAA! Just kiddin brother.
    Welcome to the fun!
    I had a gen 1 about a year ago, and I loved the hell out of it.
    I had none of the problems that are common with them, and I hope you dont either.
    Sounds like you had a "connection" to the bike, so even if it isnt the last one you ever get, at least it will be a good starter bike.... or hell, maybe you will keep it forever.
    anyways, welcome, be safe, and have fun.
    #69
  10. invisible cities
    invisible cities New Member
    new york
    Congratulations on purchasing this '84 - the 'blue on top' with the tri-color Honda Wing is a favorite of mine. Out of curiosity, were you able to do some detective work on the rims?
    On the soap box for a minute – I am not sure if this was a quick photo of you taking the bike around the block and I don't mean to be overly critical but please consider switching out your footwear. Riding with loose fitting sneakers in combination with shoes that have laces (these tend to get caught on things that they shouldn't) is asking for trouble. Consider a quality set of motorcycle boots - they are well worth the investment. Okay - off the soap box now :)
    #70
  11. tinkerinWstuff
    Looks good. Congratulations and be safe!
    #71
  12. timmah1991
    Chicago, IL
    Awh cundalini you scared me!
    Thanks for the info in the PM, I'm sure it'll be helpful soon!
    I have a question, and I hope it's just something dumb that I overlooked.
    I've put about 800 miles on the bike so far, and holy crap, I don't know why I didn't own a bike before?
    I took it to a friends house, she ran strong the whole way there, then I got off to say hi and, not wasting a minute of riding time, I hopped back on and hit the start button.
    But it never started.
    It cranks, the killswitch is in the run position, it has 3/4 tank fuel, the ignition fuse isnt the problem, the battery isn't the problem (tried jump starting with aaa truck, and the battery got charged when I got home).
    Where do I begin diagnosing this :[
    Like I said, it ran fine up until I hit the kill switch, and then tried to start it all of 30 seconds later.
    #72
  13. timmah1991
    Chicago, IL
    So the factory manual is pretty helpful so far. I'm going to go check compression on the cylinders and I'll be back shortly with the results :[
    Wish me luck!!
    #73
  14. Hawkrider
    Hawkrider New Member
    Hampton Roads, VA
    Start with the basics - spark and fuel. Sounds to me like you lost spark. Start with checking the connections to your ignitor boxes, then to the coils. Then pull one plug, attach the plug wire, ground the body of the plug to the frame, and crank a few times. If you don't have spark then that's a good start. If you do have spark then move to the troubleshooting the fuel system.
    Probably not a compression issue since you just rode it and the bike was warm when you tried starting it.
    #74
  15. timmah1991
    Chicago, IL
    That was indeed the problem.
    No spark on front left or back left plugs.
    But on a brighter note, those two same cylinders are getting about 8kpa compression, which is lower than spec, but still not 0, indicating the valve issue that I'm so paranoid of. at least not on those cylinders. I'm assuming that the bad compression is due to the cold weather and subsequently cold engine block.
    #75
  16. timmah1991
    Chicago, IL
    On a side note, one of the plugs DID produce a spark, but just one out of many cranks
    #76
  17. timmah1991
    Chicago, IL
    I tightened all the connections and put the plugs/wires back in.
    Then it started right up.
    No more long trips with this bad boy until it sees a nice tune up, eh?
    Thank god for AAA
    #77
  18. Hawkrider
    Hampton Roads, VA
    These older bikes sometimes require a little extra attention. If it happened once then it may happen again, in the same place or somewhere else. Ever had your headlight fail while riding at night? Not fun. Might be a good idea to strip the bodywork and go through each electrical connection and clean and inspect them. A little preventive maintenance goes a long way.
    #78
