WTB 87 vfr fuel pump
Discussion in '1st & 2nd Generation 1983-1989' started by mpadgett88, Dec 13, 2012.
  1. mpadgett88
    mpadgett88 New Member
    medford, oregon
    fuel pump died. so I need a new one please and thank you.
    seems gravity drain does not work on 700's?
    Many "fuel pump failures" are actually fuel pump relay failures, so you need to try the bypass or measure resistance across the 2 pump wires, which, if it's infinite DOES indicate that the pump goes to the rubbish bin.
    That pump is by no means unique to that bike and that year as it was used on a wide variety of Hondas and bikes from the other manufacturers over a long span of years, so possibly a smart salvage yard could supply a replacement.
  3. mpadgett88
    medford, oregon
    yeah they want 60 bucks. Ill check the relay can I bypass the relay to run the pump? or would it not run right
  4. mpadgett88
    medford, oregon
    also where is the pump relay? another random question. three lines coming from gas tank. ones fuel line. the other are both vents right not vacuum?
  5. squirrelman
    One line drains the pocket around the filler cap of rain water or spilled fuel.
    Pump relay is nearby the pump. Do the bypass to send power directly to the pump, then report back. Having suffered numerous relay failures, i've eliminated the relays on all my Hondas, permanently installing a jumper wire at the relay plug.
    Some think it MAY POSSIBLY be risky due to minor conflagrational issues, but not Squirrelman !
  6. mpadgett88
    medford, oregon
    the fuel pump relay is the box next to the rectifier?
  7. mpadgett88
    medford, oregon
  8. Gregg in ohio
    Gregg in ohio New Member
    kenton ohio
    fuel pump
    gold wing pumps work also cbr 600 early pumps also..jump the realy and tap on the pump with a screwdriver handle..gregg....chack all ur fuses for corrosion..
  9. mpadgett88
    medford, oregon
    anyone got a pic of the relay and position they can link for me
  10. Gregg in ohio
    kenton ohio
    its behind the Lh isde cover to the rear of the plugs harness assy small rectangular black box with a three wire plug on it..might be in a rubber vibration free holder..its solid state sealed..gregg
  11. mpadgett88
    medford, oregon
    ahh next to the rectifier? okay so I splice the hot wire off the pump and the hot wire into that together? leave grounds as is? or what
  12. Gregg in ohio
    kenton ohio
    fuel pump test
    find relay unplug from relay make a jumper wire plug into connector connecting the white wire to the black wire..might want to remove fuel line from carbs to see if it flows ,,if pressure is already built up pump will not work due to built in pressure regulator..if it doesnt work tap on it with a screwdriver handle..and or filter could be plugged also ..i jump the plug to pressure test carbs out of the bike before installing after a carb rebuild to check for leaks..gregg
  13. mpadgett88
    medford, oregon
    well I tried the bypass and it made no difference. the fuel pump doesnt pump
  14. Gregg in ohio
    kenton ohio
    fuel pump
    key on kill switch in run position..in nuetral and try jumping and tapping pump body...pull key cover and check all fuses for continuity and corrosion......if all else fails pull pump and hook directly to a 12 volt battery source..smack it a couple times it might be stuck..its a diaphram pulse type with pressure regulator never seen one die..wish i could come look at it..gregg
  15. mpadgett88
    medford, oregon
    k so i pulled pump hooked it to the batterys ground and hot. and it makes one suck nose tgen nothing everytime i touch to hot it would spark if i touch the framw with the pump it its self would spark also the pump got super hot
  16. Gregg in ohio
    kenton ohio
    pump
    ITS TOAST>>>> find another one..never seen one go bad unless its so varnished up or rusted internally...i tried ..gregg
  17. mpadgett88
    medford, oregon
    Im thinking bout picking up a mr gasket universal pump 3-5psi I think. i cant find an mitsubishi under 100
  18. Gregg in ohio
    kenton ohio
    pump
    get one from ebay ..ive heard that the cbr 600 pumps also work and the early gold wing pumps..should find a used one cheap..gregg
  19. squirrelman
    I know a possible remedy for wacha got there !
    Remove the black cover, grab the central shaft of the works (silver colored, about 5mm diameter) with pliers, then spary a bit of WD40 down into that area and pull up on the shaft about 1/8 inch to free it cuz it's stuck. Pull it up then let it spring back down a few times and that should fix it.
    Another deal that fixes some pumps sometimes is cleaning the electrical points by dragging #600 or finer sandpaper through the gap to restore the surface conductivity and remove any corrosion.
  20. lmbo
    lmbo New Member
    n.ireland
    thanks fellas will not be buying a 700 got my own woes
