wont shift into second
Discussion in 'Mechanics Garage' started by ceno91, Jul 24, 2014.
  1. ceno91
    ceno91 New Member
    my 86 vfr750 wont shift past neutral. it goes into first and neutral no problem but it wont allow me to shift up any higher. i was riding it and went to shift from first to second but it would not allow me to do so. anyone have any idea why?
  2. rjgti
    rjgti New Member
    regina sk
    drop the oil pan and see if a pin is down there, the shift segment pin for second may have come out
  3. TOE CUTTER
    You need to pull the cover off the shift shaft and inspect the operation and possibly remove the linkage and turn the shift drum manually to verify the problem is not with the drum or forks.
  4. ceno91
    ceno91 New Member
    I'll have to check that this weekend if I can get my shift at work covered... thanks for the info
  5. rjgti
    rjgti New Member
    regina sk
    true toe, or a broken shift fork
  6. squirrelman
    Bent maybe, but ye caint break them thangs.
