Wiring harness BLUES
Discussion in 'Mechanics Garage' started by Smoky73, May 13, 2021.
  1. Smoky73
    Smoky73 New Member
    The 84 vf750 I just picked up. The wiring harness is completely hacked. I thought I could figured it out. But way to many wires cut. Does anyone have any suggestions on how to get the bike to at least fire up and run. I've already done alot already. Maybe which wires I need to jump so I can start it up? Any help with this will be greatly appreciated.
    got the wiring diagram ?? check that you get + 12volts at the proper wire on the plug going to the ign black box. might help to use color codes to find out which wires going to what were cut.
  3. fink
    fink Member
    Depends on where it has been hacked. What you need to do is to get a wiring diagram for it , then sit down and look at it. Ancillaries like indicators, lights arent required .
    Where are you located Smoky?
  5. TOE CUTTER
