wiring a generic ignition switch to VFR
Discussion in 'Mechanics Garage' started by iron_monkey, Feb 2, 2015.
  1. iron_monkey
    iron_monkey New Member
    As im trying to use a 1990s VFR 750 on a go kart I simply bought a generic ignition switch meant for Honda. The switch has 3 wires coming out of it: Blue/orange and red/black wires to a connector, and a separate black wire to a bullet connector.
    Im wondering what the black bullet connector is for.
    The stock VFR ignition switch has Blue/orange, red/black, and red wires to a connector. So the only difference (it appears) is the red wire on the VFR vs the black wire on the generic. Should the two go together do you think?
  2. NormK
    NormK New Member
    No idea, complete guess, are you using the stock bike wiring loom, go kart doesn't need all the wires that a bike needs
  3. iron_monkey
    Its a stock bike loom. But I definately need the ignition wires!
    Whats the position settings on a vfr ignition? park, off, on?
  4. vfrcapn
    vfrcapn Member
    Grass Valley, CA
    Blue/orange - fan
    Red/black - ignition
    Red - battery
