Wired!
Discussion in 'General VFR Discussions' started by 99800, Apr 6, 2011.
  1. 99800
    99800 New Member
    Arizona
    Is there any wires on my 99 800 that i do not need?
  2. Metallican525
    Metallican525 New Member
    Rockville, Maryland
    If you're looking for weight savings, wiring ain't the place to start on a heavy bitch such as a VFR. :welcome: and please clarify what you're trying to accomplish.
    99800 New Member
    Arizona
    The removal of useless wiring is for more of a look consept then for weight. My bike is naked so less is better.
  4. matt1986vf500f
    matt1986vf500f New Member
    Lula, Georgia, United States
    Really there not any wires the can't be removed..the smog crap can be removed.
    99800 New Member
    Arizona
    I would do that but I live in Arizona and haven't taken it to get the emissions tested.
  6. crustyrider
    crustyrider New Member
    North Country, New York
    then you hosed...you could try to reroute the wires to loose the bull that is visable..... I would suggest putting the fairings backon and not worry about cutting up the harness.
  7. tmyoungjr
    tmyoungjr New Member
    Rochester, New York, United States
    Yeah your wiring is there for a reason and in a lot of cases isn't even sufficient. Your best bet is to make sure all of your electrical is up to snuff and then work out a routing plan that hides as much as possible.
