Will an 01 tach work in a 98?
Discussion in 'General VFR Discussions' started by 2007VFR, Apr 25, 2013.
  1. 2007VFR
    2007VFR New Member
    The 2001 VFR's had a white faced tach. Will that tach fit and function in a 98? Anyone know?
  2. Joshua C
    Joshua C New Member
    Hollister, CA
    Yes it will. The 2000 also had the same white tach. They ( 2000-2001) are the same part # from Honda - 37250-mbg-a01. The lower dash case assy (that's what Honda calls it) which the tach plugs into, and on the backside the wiring harness plugs into, is the same part # on the 98 and 2000-2001. # 37103-mbg-003. That means both tachs are plug and play.
    2001 Honda VFR800FI A SPEEDOMETER | Babbitts Honda Parts House
    http://www.hondapartshouse.com/oemparts/a/hon/506c2ad4f870023420a30ef1/speedometer
    I hope I made sense there.
    Josh
  3. 2007VFR
    2007VFR New Member
    But the 98 tach is a 37250-MBG-671.....I wonder if the difference from the 671 to the A01 is just the color?
  4. Durk
    Durk New Member
    Pittsburgh, PA
    98 tach is white.
