will a magna motor fit an intercepter?
Discussion in '1st & 2nd Generation 1983-1989' started by superstu23, Sep 1, 2009.
  1. superstu23
    superstu23 New Member
    north carolina
    i have a 84 honda intercepter vf500f can i put a 86 vf500 magna engine in it ?is it a direct swap?
  2. slowbird
    slowbird Member
    Toronto, Ontario.
    I heard the magna Engine sits the other way around
  3. Sebspeed
    Sebspeed New Member
    Catskill Mtns, NY
    Not sure if it's direct fit, but I believe they are the same engine. The baby Magnas are chain drive and fire in the same order as the Interceptor, unlike the bigger Maggies which are shaft driven and contra-rotate.
  4. Jakobi
    Jakobi New Member
    Klamath Falls, OR
    You should be fine.
    -Jake
  5. magnavmx5
    magnavmx5 New Member
    KY
    it works just fine other than some internal stuff nothing is different
