Why is my front end shaking?
Discussion in 'General VFR Discussions' started by mrvfr, Oct 5, 2010.
  1. mrvfr
    mrvfr Banned
    I dont notice anything if i hold the handle bars, but if i let go and im going anywhere from about 25 - 45 the front starts shaking, depending on the speed its pretty bad.
    i dont have any fairing on the left side, i dont notice it goign slow, or fast 55ish + it doesent shake at all.
    tire not balanced correctly?
  2. TOE CUTTER
    Most likely a bad tire but checking the head set is in order as well.
  3. mrvfr
    mrvfr Banned
    the tire was sitting in the shop for quite some time. bought it jsut a few weeks ago or so. i got a 150 tire for 60 bucks so if its the tire i caint really complain.
    noob question time, what is the head set. the pieces that hold the forks?
  4. betarace
    betarace New Member
    Middleburg, VA
    saw your other post: http://vfrworld.com/forums/general-vfr-discussions/32641-why-my-rear-end-gigglin-around.html
    check in order:
    inadequate pressures - you should run @ the manufacturer recomendation usually in the 36psi range
    tire wear - look for cupping on the sides of your tires (abnormal wear)
    lift the front of the bike (on your centerstand if you have one) and wiggle the tire up and down, if there is any play your HEADSTOCK BEARINGS are shot and need replacement
    Order a set from allballs racing (usually $34) and take to the honda dealer for installation ($75-90) or look for the numerous threads via search on how to replace
  5. Ozwanderer
    Ozwanderer New Member
    Coffs Harbour, NSW
    I found mine would shake worse and worse as tyre pressure dropped over time... keep it at 36psi
    Aa well, a new tyre (Michelin Pilot Road 2CT) made heaps of difference over the well worn Bridgestone
    No shake now.... :)
  6. Joey_Dude
    Joey_Dude Member
    North Georgia
    It's laughing at your giggling rear end
  7. mrvfr
    mrvfr Banned
    4gen btw.
    the temp did go down, will tire pressure change as temp changes. makes sense.
  8. jahlov420
    jahlov420 New Member
    Richmond, VA
    i change my front tire and it stopped on my bike.
  9. tinkerinWstuff
    another possibility: improper preload setup on front and/or rear suspension, and/or improper front fork height. If the front forks are set too low, this type of thing can happen (coupled with other symptoms like falling into a corner).
  10. mrvfr
    mrvfr Banned
    i think it must be the tire, i know its sat on the shelf long enough for the label to be well faded. it wasent doing it with the old tire.
    question is can the balancing cause this? if so i can go back to honda and ask them to re balance it for me. if not there is no need to bother them.
  11. betarace
    betarace New Member
    Middleburg, VA
    going to a dealer, a full mount/remount (with the tire off the bike) is like $25 around here. A balance check should be free and weights (if out of balance) would be $5 tops asa there is almost no labor. With tires ON the bike plan on $30 or so (about 1/2 hour labor)
  12. Pliskin
    Pliskin New Member
    Morris County, New Jersey
    I'm a fan of always starting with the easy stuff.
    You said it wasn't doing it with your previous tire, so that would seem to indicate something's wrong with the recently mounted. I'd definitely have the balance checked, and if the dealer did the original install, you shouldn't have to pay for that again.
  13. donald branscom
    donald branscom New Member
    Guerneville CA
    Front tire, swing arm bushings , or shock mount bushings.
    When the front bearings are worn it does not usually shake, it just won't correct.
  14. tinkerinWstuff
    Fixed.
    Although I don't see/understand how shock mount bushing could have anything to do with this?
  15. mrvfr
    mrvfr Banned
    strange, it doesent do it when im pulling a trailer
  16. kd4ysi
    kd4ysi New Member
    Columbia, South Carolina, United States
    mines doing it too i think cycle gear didnt ballance my tire correctly
  17. mrvfr
    mrvfr Banned
    I agree, ill be taking mine back to honda.
  18. vfourbear
    vfourbear New Member
    Louisville, KY - Under my tinfoil hat
    Haaahaaahaaaaa.................sucked in again
  19. tinkerinWstuff
  20. PorscheBob
    PorscheBob New Member
    Los Altos, California USA
    Tighten the steering head bearings. It needs a little bit of drag.
