Who lubes with gear oil?
Discussion in 'Mechanics Garage' started by powerslave, Nov 24, 2008.
  1. powerslave
    powerslave New Member
    winnipeg,manitoba.
    I'm about to install a new chain and sprockets,probably gonna stick with my tried and true Maxima chain wax,but a quick look at my owners manual made me wonder:
    Do any of you use 80-90 wieght gear oil as recomended by the manual?
    The chain wax does tend to build up and form a thick gunk that is difficult to clean.I suppose the gear oil would make for a nice shiny-clean looking chain.
    Any thoughts??????:ear:
    I know the Slick 50 comments are coming.......stick with your chain wax, unless you like oil all over your bike and the back of your leg. The anti fling properties of modern chain lubes make life a lot cleaner and easier.
    As for the shiny chain, i'll pretend i didn't read that part.......:tongue:
  3. Comicus
    Comicus New Member
    East Nashville
    I use the recommended gear lube and have no problem. But I have never used gear wax. After I lube the chain I start the engine, put it in gear and run the back tire up to 20 mph(while on the center stand). That slings the excess lube off and then take a rag and wipe up the gear oil. Not very much actually comes off. not very messy at all.
  4. KC-10 FE
    KC-10 FE New Member
    Honda uses DID for 95% of their OEM chains. DID recommends a chain wax & not a gear oil. That's reason enough for me.
    What chain & sprockets did you get. I need a new chain like yesterday.
    KC-10 FE out...
    :plane: :usa2:
  5. powerslave
    winnipeg,manitoba.
    KC,
    I got a DID chain,and PBI sprockets (16t,45t)
    The rear sprocket is made of 7075-T6 heat treated aircraft aluminum, "stronger than steel".....we'll see about that!!!
  6. mello dude
    Geek engineer alert! 7075 - T6 is tough stuff, some steels arent as strong, while other steels can be way stronger. For sprockets, its more about how the material will wear - hardness and toughness.
    MD
  7. Bubba Zanetti
    Bubba Zanetti Member
    Delaware
    Where did you buy the sprockets?
  8. powerslave
    winnipeg,manitoba.
    ^^ Bought the sprockets at my friendly nieghbourhood Honda dealer!
  9. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    Yep, I use gear oil with my Hawke oiler. Works well. Got about 25,000 out of the stock chain. Not as good as some but I'm not as dutiful as I should be about regular lubing.
  10. CaptainBart
    CaptainBart New Member
    I get a quart of 80-90 weight Valvoline at Auto Zone. So far on Quart has lasted me uh 5 years and isn't half gone. Now I have to ride to work in my class A's sometimes. So I clean the chain while I lube it. To clean the chain I use 80-90 weight Valvoline. Same quart by the way. Maybe I'm cheap. Maybe I'm smart. I don't know but I have 18000+ and I'm not to the wear zone. Sprockets are holding fine. I can give it all it's got Jim and the Class A's and the Wheels etc stay clean. dono but who sells that wax stuff and how much does it cost. Wonder if it might be related to the people that sell sprocket and chains
  11. powerslave
    winnipeg,manitoba.
    "Give it all it's got Jim"........funny cheet,mang!
  12. CaptainBart
    Wax your paint. Earl ur chain!
  13. plasma
    plasma New Member
    Merseyside England
    I allways use gear oil ,that is what it tells you in the book ,i allways go with honda
    Plasma
  14. Interceptor1
    Interceptor1 New Member
    Quebec
    [​IMG] This is the oil I use, as the chain warms up the oil get ticker and doesn’t fly away.
