Which way should the fan blow on my R/R?
Discussion in '5th Generation 1998-2001' started by L J VFR, Feb 3, 2011.
  1. L J VFR
    L J VFR New Member
    Lowell, Arkansas
    Hey guys, been a while since I have been on. Been a crazy year. To the point, I am adding the upgraded Honda R/R on my 98. I am going to add a "computer" fan on it since I have it out. Not sure it will help, but can't hurt I suppose. My question is:
    Which way do I have the fan blow? Onto the R/R, or pull air off of the R/R? Does it matter? Might be a stupid question, but thought I would ask anyway. Thanks for the help in advance. Lance
  2. Metallican525
    Metallican525 New Member
    Rockville, Maryland
    Shouldn't make too much difference, all you're really doing is circulating hot air around the RR, unless you are ducting in cool air from elsewhere it will make little difference IMO.
  3. leftcoast
    leftcoast New Member
    somewhere near Seattle, but my heart is just north
    Pretty cynical there Metal......
    I'm a firm believer in the R/R fan trick. I put one on my 97 years ago, and after 2 R/R burnouts, that configuration never failed.
    meh...who knows if it was the fan, but i'd like to think it helped.
    Regarding fan direction....depends on the orientation. If you can pull cooler (relatively) air from someplace & blow it on the R/R; or if you can remove the heat from the cooling fins & draw cooler air in from the outside....orient the fan accordingly.
    good luck!
  4. Metallican525
    Rockville, Maryland
    Umm, I wasn't trying to be cynical, I didn't say it wouldn't help. I think we said allmost the same thing with different words sir.
  5. tinkerinWstuff
