Where to put those extra wires?
Discussion in 'Mechanics Garage' started by Yakima9, Apr 1, 2009.
  1. Yakima9
    Yakima9 New Member
    Wausau, WI
    I am currently running a Vista HCX GPS and Inno XM radio off of a 12V lighter plug tucked up under the fender. I'm running a power extension from that to the tank bag, where it splits, and the plug for the GPS and XM are plugged in. The headphone extension plugs into the top of the Inno so that the volume controls can be used on the unit, rather than it being fixed output volume. This extension is also ran into the thank bag and ends up in my ER6 headphones. The 30 ft of XM anntena is run from the Inno to the tank bag and then out to the brake caliper. What sound like a giant mess of wires was turned into this recently.....
    I got the container at Menards for around $3.50 It was the perfect size for the wires in the tank bag. They had 3 other sized that were smaller and shorter. If you have a mess of wires in your bag, I would check them out.
