Where to buy luggage online?
Discussion in 'General VFR Discussions' started by Bighawk, Feb 7, 2011.
  1. Bighawk
    Bighawk New Member
    NJ
    Been looking for luggage for my 08 Silver but cant seem to find a place online that sells for any less than the stealer, any suggestions? Also, i would consider GIVI as well. If anyone knows the best sites and most inexpensive please let me know.
  2. TOE CUTTER
  3. JTC
    JTC New Member
    Watts, CA
    MotorcycleSuperstore.com has a pretty good selection of Tank and Tail bags for VFRs. A little skimp on saddle bags though...
  4. betarace
    betarace New Member
    Middleburg, VA
  5. betarace
    betarace New Member
    Middleburg, VA
  6. Bighawk
    Bighawk New Member
    NJ
    Sweet thanks guys!!!!!!!!!
    A thought occurred to me after looking at a couple sites yall put up for me, does anyone here use the generic saddlebags? I'd rather save the money and have a set of soft saddle bags that fit great on the VFR if thats possible.
    Any suggestions on brands/models? Appreciate all the info, thanks for helpin a newer VFR owner.
  7. betarace
    betarace New Member
    Middleburg, VA
    I use the BAGS CONNECTION (brand) CargoBag from Twisted Throttle... works on all 3 of my bikes and never slides... good for 3-4 days
  8. Bighawk
    Bighawk New Member
    NJ
    Did you need some sort of head pad due to the exhaust? I'm starting to sway towards Nelson Rigg saddlebags as they have "heat shields" you can purchase. Do you think these shields are necessary or are people getting away with using fabric saddlebags without any type of modification?
  9. betarace
    betarace New Member
    Middleburg, VA
    the bad has a heat shield of sorts on the bottom (rubberized) and I have never had a problem... even on the 999 which is like sitting on a frying pan
