Where is the left/right turn signal and tail light connector on a 1999 VFR800?
Discussion in 'Mechanics Garage' started by Heretic, Aug 28, 2008.
  1. Heretic
    Heretic New Member
    Armstrong, BC
    Installing a Scorpio Alarm with the "factory" harness kit - step 1:
    Simply unplug the left/right turn signal and tail light connector and plug in the "Y" connector in-between.
    It says it should be under the seat or rear tail section - but nah uh - I don't see it. :(
  2. Heretic
    Heretic New Member
    Armstrong, BC
    Well - after talking with Scorpio - It seems that Honda upgraded the VFR wiring harnesses in 2000 - so, on a 1999 - just use the "generic" kit that comes with the alarm...
  3. Dainius_M
    Dainius_M New Member
    Lithuania
    Lithuania
    About Scorpio SR-i300 alarm system installation
    There is Scorpio alarm system installation manual. http://www.scorpioalarms.com/media/sr-i300_instructions_v5.pdf
    One of the standart feature of Sr-i300 alarm system is ignition protection.
    I don't understand how the alarm system knows that ignition is on if there connected only battery+, ground, two turn signal and tail light.
    I wrote to Scorpio for support...they answered:
    It’s the Orange wire in the diagram. The Orange wire must be connected to a
    wire that only has power when the key is on.
    But it's sed that it must be conected to tail light, there is no power when
    the key is on.
    And they said that:
    The bottom line is that the Orange wire in our wiring needs to be connected
    to a wire that has power when the key is on. The MCM needs to know when
    power is turned on for some of the functions.
    Is in tail light power when the ignition key is on or not? Where I can connect may orange "tail light" wire?
  4. hatzyian
    hatzyian New Member
    Larnaca Cyprus
    If you have a bike without a light switch, then the tail light is powered when the ignition is ON. If you have a light switch (R/H switch cluster) then it is only powered with the ignition ON,--AND-- the lights switched ON
  5. Dainius_M
    Lithuania
    Lithuania
    May VFR with light switch (does can be without?) Where you suggest to connect that orange wire in tail?
