Where is the ECM reset on VFR800A 2006?
Discussion in 'Mechanics Garage' started by rmse17, Jan 1, 2011.
  1. rmse17
    rmse17 New Member
    I had a 2-blink code from the ECM, which was something with the MAP sensor. Mechanic that I called told me to change the air filter first (hasn't been changed in 13k miles), and then reset the ECM and see if the error comes back. I changed the filter, but now I am trying to figure out where the ECM unit/ harness is to reset it's memory. Could you tell me where it is at, and what I need to remove to gain access to it?
    Thanks!
  2. TOE CUTTER
    Have you tried to disconnect the battery for several minutes?
  3. crustyrider
    crustyrider New Member
    North Country, New York
    battery disconnect works best.....take it loose then reattach after 10 minutes... it should reset...much like a car does....
