Where is the battery grounded?
Discussion in '6th Generation 2002-2013' started by suse, Jan 5, 2014.
  1. suse
    suse New Member
    Nampa, Idaho
    I've got a fully charged good battery. The VFR turns over a few times and I get the, "click-click-click" like the battery isn't getting enough power to the starter. I know the connection at the battery is good. I'm not totally eliminating the possibility of a bad starter relay. Sometimes in the summer I would have the same problem. And it starts every time when jump-started. It is really cold, (19 deg F.) so this really doesn't help. Any ideas?
  2. Allyance
    Allyance Member
    Germany
    East Bay, California
    Check all your high current connections, battery, starter relay. Remove your ground first, then Positive. Undo all connections and burnish. Sounds like you have a resistive connection due to corrosion. They can pass 12volts with little current, but not the high current demands of the starter.
  3. stoshmonster
    stoshmonster New Member
    The battery is grounded to the frame rail beneath the gas tank with this bolt Curtis.
    Kinda difficult to get to,gotta raise the gas tank and the rubber flap covering the rear cylinder head to get to it.
  4. suse
    suse New Member
    Nampa, Idaho
    Wow nice bike! Interesting colors. I broke down and ordered a repair manual. I've actually never raised the gas tank. I'll have lift the tank and check all my connections again. The battery connections look good. And the battery charges quickly after it stops turning over. So, I'm sure it has to be some sort of a power delivery problem.
  5. Havoc
    Havoc New Member
    Grand Rapids, Michigan
    I don't own a gen 6 but just for well being on my 4th gen I added an extra 8 gauge ground cable and attached it closer to the battery on the frame. It seemed to help a lot.
  6. Scubalong
    How old is the battery? My will show full charge but will not hold the juice. Swap a new battery and the problem go away
    Hope this is the case.
  7. 34468 Randy
    Is that the battery I sent down to you a year ago Long? It should do better than that. But sorry....no warranty on that one.
  8. Scubalong
    Yes it is Randy..........No worry I rather pay $150 for the battery in stead of few hundres or thousand for electrical issues :rolleyes:
    Thanks Randy you did good :thumbsup:
