where is the "alternator stator 3-pin electrical connector containing 3 yellow wires"
Discussion in 'Mechanics Garage' started by TheUnnamed11, Aug 11, 2010.
  1. TheUnnamed11
    TheUnnamed11 Banned
    i wish this thing had a picture
  2. TheUnnamed11
    TheUnnamed11 Banned
    95 vfr750f
  3. TheUnnamed11
    TheUnnamed11 Banned
    guess my first question is does the stator go directly into the RR.
    battery isent charging, so i figure either stator or RR. so i figure ill test the stator first if i can figure out which wire it is.
  4. tinkerinWstuff
    the 3 prong plug with the yellow wires you seek is on the right hand side behind your middle fairing. the cable runs from the stator, over the top of the motor, to the electrical connector you speak of on the right hand side. Should be fastened next to the coil. From there, it runs to the stator.
  5. erollman
    erollman New Member
    Northeast Ok
    as always, Tink is right. its connected from the stator, to a three pin connector, then from that connector to the R.R. I personally found this wire to be too small, so i just ordered me up a VFRness and a new stator. Can't wait to get it here and installed.
  6. tinkerinWstuff
    Thanks for the kind words but "always" is a bit much. I've had egg on my face around here more than once. Good luck to you both.
  7. TheUnnamed11
    TheUnnamed11 Banned
    ok, i believe that i found the plug. on setting rx1 there was infinate connectivitity from each wire to each other wire. and on the same setting there was 0 connectivitity from each wire to ground.
    this would indicate that the stator is good and my problem is with the r.r.?
  8. TheUnnamed11
    TheUnnamed11 Banned
    again, if i didnt mention above. battery goes dead after around an hour.
  9. tinkerinWstuff
  10. TheUnnamed11
    TheUnnamed11 Banned
    well. from what the book says i think the tator is good. my stator seems to be working also. but there is still one question.
    the ohm readings seem just fine, but when i start the bike and test the wires to ground there is 0 voltage. is this normal (ac voltage to dc ground = 0)
    each wire to each wire had full contunitity, each wire to ground had 0 contunitity. from the way i understand the book it seems to have tested good.
    i cannot test my rr untill i get a better digital meter
  11. tinkerinWstuff
    I believe that you have to check voltage in AC mode from yellow wire to yellow wire. The field is creating an alternating sin wave and I don't believe there would be any reading to ground. The R/R converts that sin wave to DC voltage and then can be checked to ground.
    The thing I've never seen a single person tell me, even the guy who sells R/R's, is what that voltage would show if checked. Everyone says if the tator ohms out to the chart, it's good - which really makes sense. If it doesn't ohm out, it can't generate power. If it does ohm out, it HAS to generate power if there's a magnet rotating around it (the flywheel). So unless you've removed your flywheel, and the stator is still mounted in the proper position, and the wires ohm out to the factory manual, then the tator pretty much has to be good.
  12. Lazy in AZ
    Lazy in AZ New Member
    Mesa, Az
    Hahaha! We need a like button for some of these post responses.
  13. TheUnnamed11
    TheUnnamed11 Banned
    well. i checked the rr with a digital meeter. the 3 leads from the stator ohm tested fine. the other 2 contacts when hooked up the way the book says have 0 continuitity. if i revers the contacts its in spec, but obviously being reversed isent correct. so if this test is corect then i have a bad rr.
    im going to keep the meeter for a day and see what other tests i can do to be sure its the rr before i make the rr purchase.
    what do you think?
  14. crustyrider
    crustyrider New Member
    North Country, New York
    pull the RR .replace it.get a new one and get on with the riding
    amd Lazy we used to have something like that If I remember correctly
  15. Lazy in AZ
    Mesa, Az
    are you testing the stator or the regulator/rectifier?
    If your testing the rectifier then you'll need to do that on low DC voltage with the r/r disconnected from power in the Diode test mode. There are two readings you'll get from each diode and 12 tests altogether. Three yellow wires tested one direction to ground will give you an open line (OL), reverse the leads and you'll get a reading in the area of .562 VDC depending on the spec.
    On the OTHER side of those same yellow wires (other side of the connector) you'll get reverse readings, but if you try and read those diodes with the leads in the same direction as the previous six tests you'll get bad readings. The 6 diodes in a rectifier, if you look at the schematic, are opposed to each other in sets of 3 to regulate the circuit. When you said that you got bad readings and the reversed the leads they were good, I'm assuming that this is the type of test your doing.
    A Stator test is testing the conductivity of the wire and insuring that the ground hasn't shorted itself internally.
    Check that all of your connectors are intact and that you don't have any loose wires in each connectors. These babies tend to fall apart after 10 years or so and a loose wire anywhere in the system can prevent the battery from receiving a charge.
    If your wires check out, and your getting 'normal' readings from the diodes, check the voltage coming out of the regulator side. If your getting 13-14 VDC out of the regulator and it's making it to the battery then replace the battery.
    Electrical systems are VERY particular and without being there 1st hand to see it and test it then I'm just crap shooting and guessing. There are tests for every part of the system, but without knowing the proper place to put the leads and what settings to be on (the book isn't always perfect) then you may get false readings even though the part your testing is working properly.
    Be sure of your results before you spend your money on something you don't need!
  16. TheUnnamed11
    TheUnnamed11 Banned
    i did one final check now that i have a dependable meeter.
    solid 14 voltes ac going into the rr at the rr plug, grounding each of the 3 wires to eachother. 14v on each wire.
    14ish voltes dc comming from pin of hte rr, and 0 from the other. its definatly the rr.
    thansk everyone for helping. and thanks to hamilton for lending me his meeter.
