What's popping
Discussion in 'Mechanics Garage' started by RobVG, Apr 24, 2013.
  1. RobVG
    RobVG Member
    White Rock BC
    Took the 700 out for a second ride. After a few miles, it stared "popping" out the exhaust-- on acceleration. Not all the time, just on a good roll-on.
    What causes it and how can I fix it? I'm dying to ride but not when it's doing this.
    Thanks,
    Rob
  2. rjgti
    rjgti New Member
    regina sk
    sounds like it is running rich or has a miss fire, that popping sound is usually unburnt fuel being ignited by a hot exaust
  3. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    bad plugs, low output from ignition, plug wire, burnt valve or popcorn in the pipes.......................................
  4. kennybobby
    kennybobby New Member
    Please don't start a second thread about your carbs not working properly until you have resolved the first one--until you fix the problem we don't need to hear about every time you try to ride that it's not working.
  5. RobVG
    RobVG Member
    White Rock BC
    Fair enough
  6. RobVG
    RobVG Member
    White Rock BC
    Well, I read somewhere that an exhaust leak could cause the problem. One of the slip-ons was loose, the PO did a poor job of mounting them. There was a crease in the bell due to using the wrong clamp.
    I cut two more slots in the pipe and used a proper exhaust clamp. Took it for a 30 mile ride and the popping was gone. Like "rjgti " said, it might be rich and the added air in the exhaust might have cause the popping.
    I can't say the problem is solved do to it possibly being rich. I mean who knows, maybe the carbs clean up with the added miles.
    On a related note, When I bought it, I failed to notice that one of the header pipes is crushed. It's lost almost 50% of it's cross section. It looks like the damage is old and the PO probably road it that way but could it cause damage or how could it affect performance? Any ideas?
    Thanks,
    Rob
  7. rjgti
    rjgti New Member
    regina sk
    anytime you restrict a header pipe you cause a flow problem. the header pipe has to be replaced
  8. RobVG
    RobVG Member
    White Rock BC
    Can the header pipes be removed from the collector or do I have to find a complete unit?
  9. rjgti
    rjgti New Member
    regina sk
    they are separate I believe, devlic or someone has complete sys for that, may wanna look into that on ebay
  10. squirrelman
    You should have no problem finding a used one from a salvage yard.
    Pictures riteaid 033.jpg gallery_3647_3505_405855.jpg gallery_3647_3505_546366.jpg
