What is unplugged on my 2002 6th gen VFR?
Discussion in 'Mechanics Garage' started by judobrian, Sep 10, 2012.
  1. judobrian
    judobrian New Member
    Colorado
    I took my fairings off tonight to test my R/R and strator, when I did I noticed 2 plugs under the coolant reserve that were unplugged and taped off.
    Any idea what these are or what they go to?
    Driver side, under the coolant res.
  2. Scubalong
    Well one of them look like The o2 sensor. Does your bike got pciii or after market exhaust?
  3. judobrian
    Colorado
    Not that I know of, I just bought the bike less than 1 week ago. Stock exhaust for sure, where does the O2 sensor plug in? I should be able to trace the wire.
    I dont believe is has a PCIII, how does Honda wrap their wires from the factory? Most the harnesses look like they have been wrapped in electrical tape (at least when I compare it to the harness I see factory in my VW, Im new to working on bikes so it may be normal/factory). Ill snap pics of the wiring tomorrow when its light out.
  4. Scubalong
    There should be a male and female connector. They going together I will send you the link to the manual so you can read and connect them back together.
  5. Scubalong
  6. Scubalong
    Let me know if you need any more info. Or help
  7. judobrian
    Colorado
    Cool, thank you.
    I think the other ends of these two connectors are wrapped in the electrical tape in the image, so I think I have 2 sets of plugs currently 'unplugged'
  8. Scubalong
    That is correct.....I will try to see what is the other one is. It is hard to see from the picture. I am sure Tink or Toe will chime in by tomorrow.
  9. judobrian
    Colorado
    Do these bikes have two O2 sensors? Looking at page 2-29 of the manual, it says they are both O2... Pre-cat and post-cat sensors? Does the VFR even have a cat?
  10. Scubalong
    Yup they all do look under the header there is a big ass canister before the pipe
  11. judobrian
    Colorado
    Makes perfect sense then. I wonder why they previous owner unplugged these.... The current ones are probably bad.... Not sure if there is a way to test those? I guess plug then in and see if the bike runs like crap?
  12. Scubalong
    They might have after market exhaust and pciii the previous owner probably swap back to oem prior the sale and forgot to reconnect the plugs. Go ahead and plug them back together it should run normal.
  13. CharlesW
    CharlesW New Member
    Ankeny, Iowa
    When you have them untaped, you might want to check if someone has installed the resistor O2 sensor eliminators.
    If they have, you should see a couple of small resistors installed across a couple of terminals on the connectors.
    Whether or not that is a good thing can be open to some debate.
    It is necessary when a PC is installed, but I'm not sure about the benefits (or lack of same) without a PC.
    Note: The link in the first sentence is not from me. It was evidently added by the site. C
  14. CRFan1
    CRFan1 New Member
    Northwest Indiana
    Do you have an FI light on? If not I am guessing he has the 02 eliminators (the resistors mentioned above) installed. If they weren't, the Fuel Injection light would be on for sure.
    The guy either has a PC on the bike or he did and removed it before sale as mentioned above. Check under the seat for a PC and if it's not there, I would go ahead and plug the 02"s back in.....
  15. judobrian
    Colorado
    Yep, two resistors in both connectors. I removed them and plugged them back in, so far so good. Thanks for the input!
  16. Scubalong
    Glad we can help now go ride............:wink:
