what does the fi light mean
Discussion in 'Mechanics Garage' started by ashmaker, Aug 1, 2006.
  1. ashmaker
    ashmaker New Member
    boston,ma
    i have a 2000 vfr with the light on the bike was running rough and i installed a new battery i think ther may be an electrical problem eg. when i swtch from low to high beam the rpm gage moved (went down like 200 rpm then went back) almost like a big draw any ideas thanks
  2. ZonaMan
    ZonaMan New Member
    Tucson
    Could be a bad stator or RR unit or battery or all three. Get yourself a digital multimeter ($20 at ACE hardware), vfr manual, and USE the fault finding flow chart at Electrosport. I don't recommend their products though. Use OEM even though it's more expensive. Honda engineers know what they're doing! Good luck brother. I had to do the same thing.
    http://www.electrosport.com/electrosport_fault_finding.html
    FI light refers to your fuel injector...turn on key, FI light comes on and Fuel injector pump turns on (you can hear it), Light goes out and bike is ready to start.
  3. kajinvfr
    kajinvfr New Member
    pryor,oklahoma
    my 1998 did the thing. on the left side there is a plug with 10 or 12 thin green wires ,one of them shorted out and broke,soldered it back 5000 miles ago no problems yet
  4. ashmaker
    ashmaker New Member
    boston,ma
    thanks, i will try that. keep the rubber side down
  5. Spike
    Spike New Member
    Have you checked the famed R/R?
