water joint o-rings
Discussion in 'Mechanics Garage' started by Spensersdad, Feb 11, 2007.
  1. Spensersdad
    Spensersdad New Member
    Northern California... way northern
    So I'm replacing my stuck open thermostat, following the proceedure per the service manual when suddenly they have me replacing the water joint o-rings!
    Wait a minute, I didn't order those. Thermostat and thermostat o-ring, yes. Water joint o-ring, no!
    The water joints are two goose neck lookin' things that conduct coolant from each cylinder block to the t-stat housing.
    Have any of y'all had these leak? Do you know anyone who's had these leak?
  2. puffmanxx
    puffmanxx New Member
    Simi Valley, CA
    I have a '94. I just replaced the housing and thermostat (new O-ring too). I didn't replace any of the other rubber because it still looked ok. Armor-all the hoses is a recommendation from the shop manual. I don't think you need to replace those if you don't break the seal.
  3. moto-1971
    moto-1971 New Member
    Sydney, Australia
    Hi, I guess you only removed the cap of the housing to take out the thermostat and therefore only broke the joint between housing and cap. You would only need to use a new O-ring here. As puffmanxx said above no need to change for the job your doing unless you break their seal.
