Hi everybody, I,m fitting a Megasquirt II for my VFR800, (it will control injectors and ignition), and I totaly rebuilding the electric system(and hole bike) and for the injectors i have autotune and a broad band lambda so there is no problem but for the ignition i need a stock ignition map to get it to run, later when i add tourbo i will go to dyno and adjust it. And if someboyde now the size of injectors it will help me out a lot. My first goal is to get it to run and the goal is 140 KG (dry) and 150 horse power on crank. I have fit it in to RC45 frame and a new upside down fork Any help will be great thanks(i got a lot picture if some wants)
