Vfr track bike daily rider will not start
Discussion in 'Mechanics Garage' started by youngblood2002, Sep 14, 2013.
  1. youngblood2002
    youngblood2002 New Member
    I own a red 1995 Vfr 750. I ride it often. I turned on ignition and all the lights came on as usual. I pushed the starter button and all my lights went out and bike will not start. I checked the main fuse and all fuses and all are good. I took apart the housing for the push button starter and sprayed wd40 and put it back together. When I put key in ignition and turn to on position still no lights on instrument panel comes on.Any ideas???:confused:
  2. TOE CUTTER
    Did you check the connector at the start relay?
  3. squirrelman
    Loose/corroded main ground wire or battery terminals or bad ignition switch. Test battery voltage with your multimeter.
  4. friedleyjr
    friedleyjr New Member
    Bossier City, La
    battery is probably the issue.
  5. youngblood2002
    How do I check to see if connector is good?
  6. youngblood2002
    I keep battery on a trickle charger.The indicator light on the chargee is green
  7. Rollin_Again
    Rollin_Again Member
    Duluth, GA
    Just because the charger shows green doesn't mean that the battery is 100% good. The starter needs alot more power than is required by the lights / display so I would start by taking the battery to a parts store to get it tested. You can also try jump starting from a car battery but make sure the car is not running when jumping it. Also check the kill switch as well as the safety switch built into the sidestand.
    Rollin
  8. youngblood2002
    I replaced the starter relay. I turned key and instrument panel lights came on but extremely dim and not enough power to start bike.My trickle charger still showed a green light signifying that battery was good. I had battery tested and it showed that 12 volt battery was only putting out 8 volts.I installed a "Powersports Battery" and bike started. I was told that a battery can have a bad cell and still show "Good" on trickle charger. this low voltage can cause a short circuit, which explains my starter relay burning out.
