VFR custom intake?
Discussion in '1st & 2nd Generation 1983-1989' started by mpadgett88, Dec 16, 2012.
  1. mpadgett88
    mpadgett88 New Member
    medford, oregon
    are there any options? or has anyone ever made an custom intake with more access and air flow. the intake now is pretty much buried under the tank lol
  2. MrSleep
    MrSleep New Member
    Verdigris, Oklahoma
    I saw on here that someone took off the air box and somehow mounted four of those little k and n cone shaped automotive valve cover mounted crankcase breathers directly to the intakes. Not sure how he got them to mount up or how much it helped or hurt performance but I'm sure it was quite a bit louder!
  3. mpadgett88
    medford, oregon
    yeah i saw that. looks like a lil too open. could be hard on motor plus would need too much fuel compensation
  4. tinkerinWstuff
    I've seen people make larger intakes and lost HP on a dyno test.
    There's no simple solution with this stuff. People who buy sport bikes want fast shit. Honda has lots of resources and engineering staff designing the best product for the money accessible to their target market.
    you think if the answer to more power was a bigger hole in the airbox or something similar that Honda wouldn't have just sold it that way?
    http://motorcycleinfo.calsci.com/Airboxes.html
  5. reg71
    Sikeston, MO
    I wonder how the bike with the K&Ns is doing? would be interested in dyno and fuel mi changes
  6. mpadgett88
    medford, oregon
    just wanted lil more airflow and access. i mean i cant even spray starter fluid in it with the tank on. no need for more power
  7. mpadgett88
    medford, oregon
    also i want it louder
  8. Dukiedook
    Dukiedook New Member
    Kansas City, USA
    Custom is the word, whatever you can modify to increase flow would be totally custom- drill holes in the airbox, totally take off the airbox and use K&N podz filters, whatever. There is no custom off the shelf stuff that exists.
    Buy a used Yoshi pipe but combined with changes to the intake you will definitely have to change jetting on your carbs to compensate for these changes.
  9. safetypro10
    safetypro10 New Member
    Dallas, TX
    How about adapting the VFR800 FI to it?
    Larry
  10. Rainbow7
    Rainbow7 New Member
    Muslim-free Queensland
    [video]http://www.motorcyclenews.com/MCN/News/newsresults/General-news/2010/May/may2710-shervin-an-internet-motorcycle-celebrity-is-born/[/video]
  11. squirrelman
    HAHAHAHA !:crazy: Not at all practical or even sensible imo.
  12. 4a15
    4a15 New Member
    Cincinnati
    Just yank the rubber boots off the front of the airbox. That will open it up to let a little more air in and make it more obnoxious (louder). Then take it for a run. You will know real quick if you screwed up the air / fuel mixture. Best part... you can put them back on when you realize you were just wasting time.
    As far as needing starting fluid. You probably need to adjust the choke cable at the carb end.
  13. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    look at this bad boy
