VFR Carb help?
Discussion in '1st & 2nd Generation 1983-1989' started by vmxwinn, Jan 26, 2011.
  1. vmxwinn
    vmxwinn New Member
    Danville, CA. (S.F. Bay Area)
    Starting this resto on my 86 700. So first off I want to get it running well before tearing it down. I got the bike with the carbs off and torn down, some people should not have tools. I them all sorted out and but the float bowl gaskets are gone along with a couple of o-rings.
    Are the float bowls the same for the VF1000 as the VFR? Cause I found a cheap set on line otherwise I have to buy the rebuild kit and they are $35 each. ouch!!
    Any help would be great.
  2. Marrib
    Marrib Insider
    Phx, AZ
    Send a private message to Toe Cutter. He can help.
  3. vmxwinn
    vmxwinn New Member
    Thanks Marrib
  4. tinkerinWstuff
    +1 for TOE. If I was in a betting mood, I'd speculate, and feel good about my odds, that the gaskets are different. TOE will know the way.
  5. Fazer1Sniper
    Fazer1Sniper New Member
    +2, he's one of the local Carb Guru's on here... Helped me
  6. Dukiedook
    Dukiedook New Member
    Kansas City, USA
