VFR 800 Fork seal change problems
Discussion in '5th Generation 1998-2001' started by Mr fixit, Aug 12, 2006.
  1. Mr fixit
    Mr fixit New Member
    I need help with this one.
    I cant get the bolt at the bottom [the one which screws into the lower bush] of the forks to come out, I have tried evreything but still no luck.
    Is there a trick to.
    Any idea's would be very helpfull.
  2. jev.
    jev. over there
    a long allen socket and air gun. if you don't have those you use an allen and put your fork leg in a vise(with plenty of protection) and use a closed end wrench on the L part of the allen and use the wrench as a torque multiplier.
  3. jethro911
    jethro911 Member
    Merrickville, Ontario Canada
    Generally you can get them to turn but they just spin, is this the case?
    Or you may have a tightie? Air wrench is really the best way to get this done!
  4. Mr fixit
    Mr fixit New Member
    Yes the problem is they just turn inside.
    Do you know how to stop the piston inside turning?
    I have compressed the forks to try and stop the turning but still do good.
  5. jev.
    jev. over there
    There is a tool you can buy to stick down inside the tube that keeps the interals from turning. I have had some luck in extending the fork and holding it in that position as tightly as I could and was able to turn the bolt w/o the internals turning.
  6. Mr fixit
    Mr fixit New Member
    Thanks for your help I applyed pressure to the internal pistion rod and with the forks upsidedown I managed to unscrew the bolt,
    All done now thanks for your help.
    Back on the road great
  7. ZR4LP
    ZR4LP New Member
    what tools would i need to replace seals on front Fork? remove shock would be step 1 after u removed front mud gaurd and loosen the 2 clamps around the top. Does the whole shock need to be under pressure to open and reassemble it ? Would i be able to reassemble it without special fork tools etc? What oil ATF??? or dedicated Fork oil and how much ? I am really going to mess up this job ! then walk to work or wheelie it. Johan
