VFR 750 FG (1986) Suspension Preload Spacer
Discussion in '1st & 2nd Generation 1983-1989' started by Tedric, Aug 21, 2007.
  1. Tedric
    Tedric New Member
    Derbyshire. UK
    Hello all, wonder if you can help me out.
    Just dismantled the forks, put in Cartridge Emulators & new springs from Race Tech (totally transformed the handling).
    However the previous spring was a Hagon progressive & the original Crucible plastic spacer had been cut down which gave an overall preload of 20mm. I have done the same with the new setup, but would like to know if any body knows the actual length of the original crucible spacer. From this I can determine the correct preload (I know what the o/e spring length was including washers).
    Many thanks
