Vfr 750 1995 engine replacement
Discussion in 'Mechanics Garage' started by Erico, Sep 5, 2020.
  1. Erico
    Erico New Member
    South Africa
    Hi, can someone assist me with any information regarding the VFR engine replacement. My wife's VFR motor is shot, will a 91 model engine fit in the frame of 95model? Are they the same motors!! TX
  2. ridervfr
    no, they have different speedo drives and gear shift levers are different, the motor mounts might line up, and then maybe you can retro fit all the ancillary parts I mentioned above. It might be a mission for sure, btw the frames are different too. You could be the pioneer there for sure.
