VFR 400nc30 charging problem
Discussion in 'Mechanics Garage' started by lucasmax, Sep 26, 2008.
  1. lucasmax
    lucasmax New Member
    bristol
    My battery seems to be fine and then it kind of dies after going for a ride. and there is a clicking sound from the rectifier. i have changed this and also tested the altenator, and bought a new battery so it dont seem to be any of these, please help many thanxs...........:unsure:
  2. goinphaster
    goinphaster New Member
    California
    Check the grounds. 400's came from Japan where they are abused by some very nasty weather(salt ther in the U.K. too). I would pull all the connectors for the battery and charging system and clean all the terminals. I would remove all the grounding points and run them over with a wire brush. if that doesn't work I would have the altanater tested with a megger by an electrician to see if it was fried.
