VFR 3rd gen AICV?
Discussion in 'Mechanics Garage' started by ThickToast, Mar 30, 2014.
  1. ThickToast
    ThickToast New Member
    Springfield,Illinois
    Air injection control valve... There's a vacuum tap off the manifold and I've always made sure it's connected but I don't quite understand what this apparatus does. The tech manual isn't helpful. Can anyone elaborate?
    Thanks,
    TT
  2. ThickToast
    Crap, it's the PAIR system... Anyone have a link or info on a removing and capping the ports?
  3. kennybobby
    kennybobby New Member
    It's a lot of trouble to do properly and doesn't affect engine performance--it's all downstream of the combustion chamber and just bleeds some clean air into the exhaust mixture. The front side is easy to remove but you'll be cussing like a sailor when you get to the rear.
  4. tinkerinWstuff
    Like Kenny said, leave it alone. It isn't hurting performance one little bit.
  5. ThickToast
    yep, you're all right. It stays on. I'm having enough problems with the damn carb sync process as it is.
