Vfr 1996
Discussion in 'General VFR Discussions' started by mchsoto, Feb 27, 2013.
  1. mchsoto
    mchsoto New Member
    NJ
    I REPLACED MY R/R AND STILL NO POWER LITES NOTHING ANY IDEAS PLZZZZ:frown:
  2. ridervfr
    Belgium
    Look at the starter relay near the battery. Chances are thats melted...
  3. mchsoto
    mchsoto New Member
    NJ
    Starter relay is what connects to the r/r correct if so iam on it
  4. ridervfr
    Belgium
    starter relay is right next to your battery. it has a 30 amp fuse i believe.
  5. ridervfr
    Belgium
    check your three yellow wire connection on the same side as your r/r. thats the stator. that goes to the three yellows coming off your r/r. they could be fucked as well...other than that, dont know what to tell you, except pictures are greatly appreciated.
    :worthless:
  6. squirrelman
    Here's one of my '86 melt-downs, a classic i guess........
    AmaZING but true, that mess was still charging but soon to fail.
  7. mello dude
  8. mchsoto
    mchsoto New Member
    NJ
  9. mchsoto
    mchsoto New Member
    NJ
    WHERE do i purchase the harnest the plastic connector to the r/r
  10. mchsoto
    mchsoto New Member
    NJ
    i have a 96 vfr looks diff about 5 plugs only one is burned out
  11. rainman6
    rainman6 New Member
    NZ
    Many people on here (including myself) throw the troublesome plugs away opting for soldering the wires together or twisting the wires together and using some 30amp screw connectors.
  12. mello dude
    Dude - first step - battery good? - You said no lights, no power. -- The r/r connector isnt gonna fix that. -- -But if you do want to do the connector fix, look in the failures thread for good suggestions.
