VF500F CO level ?
Discussion in '1st & 2nd Generation 1983-1989' started by Octanis, May 22, 2009.
  1. Octanis
    Octanis New Member
    Has anyone measured CO level of VF500F? My bike is running propably too lean, idle CO 0.12-0.16%. Pilot screws won't help at all.
  2. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    how do the plugs look? are you popping a lot(backfiring) under downshifts? does it take a while before it warms up and you can drive off cleanly without choke?
  3. Octanis
    Octanis New Member
    Difficult to say how the plugs look. About 150 miles of drive after I put new piston rings. Warms up pretty fast. Hesitates a little when turning full throttle.
  4. JamieDaugherty
    JamieDaugherty New Member
    Fort Wayne, IN
    How are you checking the CO level?
  5. matt1986vf500f
    matt1986vf500f New Member
    Lula, Georgia, United States
    sounds like to me it needs the correct jetting
  6. Octanis
    Octanis New Member
    I use Bosch automotive CO meter. Like this but it displays only CO: [​IMG]
  7. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    the vf500's dont have any sort of air injection into the exhaust right?
  8. Octanis
    Octanis New Member
    No, just straight pipe.
  9. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    im just saying like the pair valves on the 6th gens. where air is injected into the ehaust ports...
    that could really throw off your readings into the lean region...
  10. JamieDaugherty
    Fort Wayne, IN
    Oh man, stuff like that didn't show up on motorcycles until 15 years after the VF500F was made.
    It could also be a vacuum leak (or leaks), that will also cause a lean condition. On older bikes like this it's most likely a combination of several factors.
  11. Octanis
    Octanis New Member
    Almost impossible that all four cylinders leaking. Well, nothing surprises me anymore with these.
  12. JamieDaugherty
    Fort Wayne, IN
    You don't need all four to be leaking, one is enough.
  13. Octanis
    Octanis New Member
    I measured straight from downpipes. Every cylinder separately.
  14. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    did you measure it with open exhaust?
  15. Octanis
    Octanis New Member
    Open and closed. Same readings.
    Edit. And meter is fully working. We use it very often for cars.
  16. JamieDaugherty
    Fort Wayne, IN
    I wondered the same thing.
    You got the same readings with open exhaust and with the whole system installed? That sounds more weird than anything else!
  17. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    yeah you should be running much leaner with the system off then on.
