vf500f '84/'85 engine carb questions.
Discussion in '1st & 2nd Generation 1983-1989' started by xwarp, Apr 12, 2010.
  1. xwarp
    xwarp New Member
    vf500f '84/'85 engine carb questions. (come on....help a newb.....)
    here is the deal:
    parts bike is a 1984 california emissions setup.
    resto bike is a 1985 49 state set up.
    engine in 1985 was removed due to corroded carbs and rust in intakes. engine in 1984 runs very good, so i removed it to put into 85 frame. the carb rack is out currently for a complete rebuild. now, here is where i need some opinions.
    (constructive opinions as i know the risks with the vf500f's already, so squirrelman, no need to reply in kind, unless you have something to offer that is helpful......LOL)
    1st. since the carbs i am using are california type, and 1984. will the jet size difference be an issue?
    reference this reply from another thread:
    http://vfrworld.com/forums/1st-2nd-generation-1983-1989/28752-1986-vf500f-main-jet-sizes.html#post238164
    2nd. since the engine/carbs are from a 1984 cali bike, should i be using the cdi box for that bike, or will the cdi on the 1985 49 state bike be fine?
    any suggestions on these two questions?
  2. xwarp
    xwarp New Member
    nobody?
    did i post this in the wrong forum? on the wrong message board? what?
  3. jonnywishbone
    jonnywishbone New Member
    Shoreham, Vermont
    I would narrow down your thread title, vf500 carb , I may be wrong but I think the jetting issue is only different with the 86'
  4. blitzas
    blitzas New Member
    For the second question, I have seen nothing else for VF500 but:
    17 deg@1700rpm - for F mark
    37 deg@3300rpm - full advance
    If you have a timing gun you can install and check both sets and notice any differences, though few degrees wouldn't be easy to discriminate.
