Vf500 rear engine downpipes
Discussion in '1st & 2nd Generation 1983-1989' started by shortstockevs, Jan 20, 2013.
  1. shortstockevs
    shortstockevs New Member
    Hi guys
    Can you confirm which one goes to which side. One pipe has a performed indent and I don't know which side it goes on ?
    Cheers
    Chris
  2. JamieDaugherty
    JamieDaugherty New Member
    Fort Wayne, IN
    Not sure exactly what you mean, but the pipes should curve together when installed. There is a heat shield that connects the two. If you have that it would really help clarify how they are positioned.
  3. shortstockevs
  4. shortstockevs
  5. JamieDaugherty
    Fort Wayne, IN
    Look at your collector box: you will see that the two downpipes are much closer together than the exhaust ports in the head. If you put the downpipes on backwards it will be very obvious. If they line up with the collector box they are right.
    Good luck!
  6. jeremyr62
    jeremyr62 New Member
    Ireland
    Limerick, Ireland
    As you sit on the bike it goes to the right. At least that's what I wrote on mine when I took them off to paint them.
  7. JasonWW
    JasonWW New Member
    Hou. TX
    This is a bit off topic, but did the paint hold up?
  8. jeremyr62
    Ireland
    Limerick, Ireland
    So far yes. Not exacty done much mileage since though. BBQ paint it was.
