Vf500 clutch push rod leak
Discussion in 'Mechanics Garage' started by shortstockevs, Apr 7, 2013.
  1. shortstockevs
    shortstockevs New Member
    Any suggestions got a leak on the clutch pushrod oil seal, already have replaced the seal internally when the engine cases were split and new push rod all new genuine Honda parts.
    Getting annoyed with the bike now ?
    Any suggestions.
    Also small water leak from telltale hole on water pump , any suggestion there
    Cheers guys
    Chris
  2. jwf88
    jwf88 New Member
    i think im having this exact problem myself.... very interested in solutions
  3. shortstockevs
    Which problem water or the oil from the push rod.
  4. joerider
    joerider New Member
    Horsham - Collegeville, PA
    Make sure the push rod does not have any knicks iin it. The necked down portion, drawings show that should be to the left of the bike but common sense and no leaks even with a turbocharged motor say that necked down portion goes to the right sinde..... also make sure you crankcase ventilation is working
  5. shortstockevs
    Thanks, what makes you say the rod should be turned the other way around against both the Honda and clymer manuals?
    I will check the breather system as you suggested good point
    Regards
    Chris
  6. joerider
    joerider New Member
    It does NOT leak when it's set up that way. Also if you look at things disassembled, there's a LOT of things going on in the neighborhood of the clutch hub area right where the necked down portion of the rod is.
  7. jwf88
    jwf88 New Member
    Did you try turning the pushrod around?
