VF1000RE - 2 Here we go again
Discussion in '1st & 2nd Generation 1983-1989' started by thx1138, Jul 12, 2015.
  1. thx1138
    thx1138 New Member
    Perth
    So a while back I bought another 84 VF1000RE.
    My only excuse is it looked lonely and needed rescuing.
    Needs a bunch of work of course. But has an interesting 4:2:1 exhaust and has a new lithium iron battery in it.
    Main jobs to be done;
    New steering stem bearings, - done
    Sort out why engine will not idle - races, then dies
    Replace hacked up wiring harness with fully restored used one - mostly complete
    sort out charging system
    replace fuel filter, pump and relay,
    replace all the non standard fasteners with correct ones
    replace both radiators with a really nice set from ebay Japan.
    Replace tyres with new avon azaro ST radials
    flush engine with rust remover
    Probably replace the fairly worn disks with nicer ones
    rebuild starter motor while bike is apart
    Adjust valve clearances
    maybe carb rebuild or just replace them with my rebuilt euro ones
    etc
    etc
    How it looked originally;
    Now looks like this'
    Clutch slave cylinder and piston were pretty manky.
  2. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    Nice find good to see them get back on the road the right way.
    I found one with zero, that's right zero miles on it a few weeks back. Couldn't buy it though.
    [​IMG][​IMG]
  3. thx1138
    thx1138 New Member
    Perth
    The Barber museum?
  4. GreyVF750F
    GreyVF750F Member
    Yep. they even have a NSR750 oval piston bike. Notice how they support the bikes?
  5. thx1138
    thx1138 New Member
    Perth
    I think the NR is one of the most perfect looking bikes ever made.
  6. RotaryRocketeer
    RotaryRocketeer New Member
    OKC Metro, OK
    Is that including the tailpiece that looks like an overloaded diaper with vent holes?
  7. thx1138
    thx1138 New Member
    Perth
    I'm sorry, I just don't see that.
    I see a bike I would sleep with if the opportunity arose.
  8. carr
    carr New Member
    medina,ny
    I feel your stress bro,mine looks the same as yours,but we have to get them back on the road right?
  9. hopit88
    hopit88 New Member
    Looks like fun. I'm still staring at my 3 R projects with no progress. Maybe this will help.
  10. carr
    carr New Member
    medina,ny
    Take your time theres alot of us out here,we will just keep pep taking each other.
  11. thx1138
    thx1138 New Member
    Perth
    Continued taking the electrics off tonight. Every connector block has significant corrosion on all the contacts.
    The fuse for indicators and horn showed heat damage to the fuse socket. Not surprising really.
    Just discovered pool of brake fluid under the middle of bike. So rear master cylinder is coming off and being replaced with one which doesn't leak.
  12. GreyVF750F
    GreyVF750F Member
    If your fuse pannel is bad let me know, I think I have a good one. Just pay shipping from Ohio USA.
  13. thx1138
    thx1138 New Member
    Perth
    Thanks for the kind offer Grey.
    Fortunately I have a couple of spares as well from a fleabay Japan seller a year or so ago who must have parted out a pristine 1000r. All the parts, including the electrical parts, looked new.
    Only killer with Japan is the price of ems shipping.
  14. thx1138
    thx1138 New Member
    Perth
    Finally spent a bit of time on this bike.
    Stripped out the leaking rear brake master cylinder, removed it and the rear caliper. I'm fairly sure I have already refurbished spares in the brake parts box.
    Looks like the rear disk is almost at minimum thickness so the rear wheel will have to come off to replace it with a better one.
    I'm sure that will lead to the discovery of more jobs. What is it that most old bikes seem to have been maintained by torque hammer owners?
  15. GreyVF750F
    GreyVF750F Member
    I have mine, where's yours? [​IMG]
  16. thx1138
    thx1138 New Member
    Perth
    I have separate tools, hammers and torque wrenches, not a combined tool like yours.
  17. thx1138
    thx1138 New Member
    Perth
    My new parts bike for spares for the 2 RE's.
    An 84 VF1000FE with a minor engine problem.
    Has a good water pump, new battery, useable forks, some of the other electrical parts and assorted salvage.
    I'm hoping for a decent set of rocker arms.
    The bike came with a lower fairing to make it look like a 1000R, and fairly well made too.
  18. thx1138
    thx1138 New Member
    Perth
    Water pump coming off the parts 1000F to replace the one on the RE with a broken XXXXXXing bolt stuck in it.
    Broke two screw/bolt removers trying to get the frozen bolt remnant out.
  19. thx1138
    thx1138 New Member
    Perth
    Rear wheel off tonight to replace rear disk and sprocket carrier bearing.
    Damper rubbers need replacing too.
  20. cardesignmind
    cardesignmind New Member
    Minnesota
    How's it coming along? This is a bike I've always liked. Was interested in seeing your progress.
    Sent from my iPad using Tapatalk
