VF1000R Bore Liners
Discussion in '1st & 2nd Generation 1983-1989' started by thx1138, Sep 16, 2012.
  1. thx1138
    thx1138 New Member
    Perth
    Are the bore (cylinder liners) removable and replaceable on the VF1000R's?
    If so are they wet liners and is it an engineering job?
    Thanks.
  2. TOE CUTTER
  3. 2Topia Cycles
    2Topia Cycles New Member
    Been wondering the same thing....I will tell you this...there sure isnt much out there in piston selection!
  4. JamieDaugherty
    JamieDaugherty New Member
    Fort Wayne, IN
    Yes, you can remove them. I'm not sure about the replacement part though - those are special flanged parts and are not available anywhere that I know of. LA Sleeve might be able to help. Make sure you are armed with a thick wallet!
  5. thx1138
    thx1138 New Member
    Perth
    Thanks Jamie, I have a NOS set of 85/86 VF1000F (VF1000F2 Boldor not released in the US) crankcases and the liners are (obviously) new. I can get std rings and have the NOS std pistons already. The cases look to be identicle to the 1000R ones, may have to do a trial fit- if they are the same castings it will save a lot of rooting about.
  6. thx1138
    thx1138 New Member
    Perth
    Update on this ancient thread.
    Liners are easily removable. On the junk crankcases I have I gave it a go and they come out very easily.
  7. NormK
    NormK New Member
    Obviously went a bit better than your CB cases:congratulatory:
  8. thx1138
    thx1138 New Member
    Perth
    Ja, but that wasn't hard. These are wrecked from the dropped rod so good to experiment on.
    Mr Sledge Hammer almost paid a visit but was not needed in yet end.
    The crank on this bike has lost 2 mm from the journal of the failed rod. The Ros itself has a big end ID 1mm bigger than it should be. Three mm of steel worn away between them. I cannot find any bits of bearing shell in the sump and there were no big end bearing shells on that rod. Strange but true.
