vavle adjustment
Discussion in '1st & 2nd Generation 1983-1989' started by jahlov420, Jun 9, 2010.
  1. jahlov420
    jahlov420 New Member
    Richmond, VA
    does anyone know when the vavles should be adjusted...my bike has 50k on it but i got it when it had 43k on it. it runs fine but anyone know signs of when they need adjusting?
  2. invisible cities
    invisible cities New Member
    new york
    **I did not realize that your bike is an '87 VFR700. The maintenance schedule below is for a VF500F.**
    **VF500F** Factory Manual Valve Maintenance Schedule
    Valve Clearance Adjustments
    • 600 mi
    • 8,000 mi
    • 16,000 mi
    • 24,000 mi
    If you are unsure of your bike's history I would recommend inspecting the valves now. It is a very important part of maintaining a VF500F.
  3. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    you probably should check them to see where there are now. Best to lash them a loose .005". Tight lash of .005" or less doesn't help the cam wear for these particular engines.
  4. TOE CUTTER
    +1. Best to put your mind at rest and check them and have a starting point for your future services.
  5. Hawkrider
    Hawkrider New Member
    Hampton Roads, VA
    His sig says he's got a 700.
  6. invisible cities
    new york
    Thank you for the catch - I was in VF mode.
