Unknown connectors on VF500F
Discussion in '1st & 2nd Generation 1983-1989' started by caferacer73, Jan 31, 2010.
  1. caferacer73
    caferacer73 New Member
    Vancouver, WA
    I have a couple of connectors that don't have anything connected to them. Connector#1 has white and green wires. Connector#2 has blue, black and white wires (might be the fuel cut relay?). both of these are located on the left side near the rear tire. Connector#2 has a jumper across the black and white wires.
  2. JamieDaugherty
    JamieDaugherty New Member
    Fort Wayne, IN
    The jumpered connector sounds like the fuel pump relay. Those relays were known failures and it was common for people to just jump the connector to fix it. Nothing wrong with that.
    Maybe the other one is the fuel pump itself, but I would have to double check my wiring diagram to see if the wire colors agree.
  3. caferacer73
    Vancouver, WA
    Slight problem, no fuel pump or filter. I've heard of making these bikes gravity fed instead of using the fuel pump. Would this be the way to do it?
