tyres and heights
Discussion in '1st & 2nd Generation 1983-1989' started by sarg, Sep 16, 2006.
  1. sarg
    sarg New Member
    melbourne
    Gday
    I am wondering the seat height that a VFR750F should be at ? and if it can be raised....I am 6Ft 2 and love this bike. also, what are wider tyre packages that may fit??? sometimes you just wanna play and change heaps
  2. chimeraone
    chimeraone New Member
    Dallas TExas
    Tire Widths
    Here are the manufacturers fitment recommendation for the 86 VFR750F. Sorry if the various charts get a little mixed up.
    Tires: 1986 VFR750F
    Brigestone Battlax BT-45
    072443 110/90-16M/C 16 BT45F BW TL - 59V V 23.8 4.4 6 (2.50)2.15-3.00 536 43
    072451 120/80-16M/C 16 BT45F BW TL - 60V V 23.6 4.8 6 (2.75)2.50-3.00 551 43
    072648 130/80-18M/C 18 BT45R BW TL - 66V V 26.1 5.2 9 (3.00)2.50-3.50 661 43
    072656 140/80-18M/C 18 BT45R BW TL - 70V V 26.8 5.6 9 (3.50)2.75-3.75 736 43
    Continental TKV 11 / 12 A true sports tyre for older machines Optimum handling in all conditions Maximum bite at all angles of lean
    110/90 - 16 M/C 59V TL TKV 11
    120/80 - 16 M/C 60V TL TKV 11
    130/80 - 18 M/C 66V TL TKV 12
    150/70 - 18 M/C 70V TL TKV 12
    DUNLOP The V-rated GT501 features bias-ply construction and incorporates a radial-style tread pattern for contemporary styling and a larger footprint. An optimized profile creates a larger contact patch for increased cornering confidence, with smooth side-to-side transitions. Increased tread-to-void ratio delivers superior grip in dry conditions, with a high level of grip in wet weather. Increased center tread depth provides improved wear characteristics and enhanced water clearance. Rear compound increases grip and wear resistance.
    110/90-16 59V BW 3004-28 2.50 23.56 4.59 5/32 535 @ 42
    120/80B16 60V BW 3004-68 2.50 2.75 23.62 4.75 5/32 550 @ 42
    130/80-18 66V BW 3004-83 3.00 25.95 5.10 8/32 660 @ 42
    • Metzler LASERTEC New compound with high Silica developed for outstanding grip both in dry and in wet enhancing riding performance even on the most sporty bikes
    • State of the art "Sport Touring" carcass design with lighter, more resistant Polyester fibre giving higher comfort and improving handling characteristics
    • "Classic" tread pattern design ensuring effective water dispersal for safe wet riding and wear regularity with long-lasting mileage
    120/80VB16M/CTL(60V) LASERF
    130/80V18M/CTL(66V) LASER
    AVON - Supervenom AM20/AM18 - A V-rated (149mph) premium crossply tyre, the Supervenom is ideal for 1980s superbikes and was developed from the production class-winning TT bikes of the ’80s. Its specially formulated rubber compound is on the ‘soft’ side for ultimate grip, while its computer-designed tread contour is designed to provide the biggest footprint, whatever angle your bike’s cranked over at.
    Supervenom AM18
    130/80-18 66 V MT3.00 2.5 3.5 132 5.2 667 26.3 493 306
    Supervenom AM20
    110/90-16 59 V MT2.50 2.15 3 120 4.7 603 23.7 551 342
