Turn Signal Problem
Discussion in '1st & 2nd Generation 1983-1989' started by Belgarion, Sep 13, 2011.
  1. Belgarion
    Belgarion New Member
    Minnesota, USA
    Today I found that the left turn signal in front isn't working. The running light illuminates perfectly, but when signaling nothing happens at the front (rear blinks quickly as you'd expect). I swapped bulbs in front to no effect; both bulbs are fine. I'm guessing this is not a new issue as the "broken" signal has a much cleaner, newer looking bulb. I took off all the front fairings to look at the wiring and I found some connections that were loose, but reconnecting them has also had no effect. Possibilities?
  2. RedEye669
    RedEye669 New Member
    Same thing happened to me recently, there was a broken wire inside the light assembly.
