Trivia type question on engines.
Discussion in 'Mechanics Garage' started by donald branscom, Apr 22, 2010.
  1. donald branscom
    donald branscom New Member
    Guerneville CA
    OK ...Lets see who knows this.
    Why is there a little punch mark on every carberator screw?
    Look at your float bowls etc.,.
  2. VT Viffer
    VT Viffer New Member
    South Carolina
    Is that where the thread starts on the other end as to avoid cross threading the expensive (and aluminum) carburetor bodies? Just a guess...
  3. KC-10 FE
    KC-10 FE New Member
    It's what's referred to as "Staking". It's commonly done on a fastener that doesn't allow the use of a lock washer. It's purpose is to keep the screw from backing out.
    KC-10 FE out...
    :plane: :usa2:
  4. donald branscom
    Guerneville CA
    No,, The punch mark is on the HEAD of the phillips screws.
  5. donald branscom
    Guerneville CA
    No... the punch mark is on the Head of the phillips screw.
  6. donald branscom
    Guerneville CA
    One more try and i will give the answer.
  7. Lgn001
    Lgn001 Member
    Russian River by Ocean, CA
    Too many workers with not enough to do and a strong union?
  8. tinkerinWstuff
    identify that the screws were torqued/inspected
  9. donald branscom
    Guerneville CA
    No Republican answer will not work on this.
  10. betarace
    betarace New Member
    Middleburg, VA
    so that they can be correctly indexed
  11. donald branscom
    Guerneville CA
    ANSWER:
    All the
    japanese motorcycles after 1964 have this punch mark on the carb screws.
    The reason is that they changed from the IJS (International Japanese Standard), to the ISO (International Standards Organization) threads on the screws.
    So to keep mechanics from using the wrong screws and causing a leak or a fire the punch mark was put on the screw to identify it as a ISO type screw.
    I found out in 1968 when I started working in my first HONDA shop job as a mechanic.
  12. donald branscom
    Guerneville CA
    No. Sorry not the correct answer.
  13. donald branscom
    Guerneville CA
    Thanks for the courage entering the TRIVIA quiz.
