Trivia question ii.
Discussion in 'Mechanics Garage' started by donald branscom, Apr 22, 2010.
  1. donald branscom
    donald branscom New Member
    Guerneville CA
    Which Motorcycle Company had the only motorcycle sold in the USA that did NOT have shifting forks to change gears?
    For extra points... What DID it use to shift gears?
  2. TOE CUTTER
    I give up......lets have it.Google no help at all.
  3. daveyto
    daveyto New Member
    Scarborough, Canada
    You got me on this
  4. jethro911
    jethro911 Member
    Merrickville, Ontario Canada
  5. tinkerinWstuff
    Ridley isn't Japanese
  6. tinkerinWstuff
    oh stand corrected - he didn't specify japanese. I got the last question confused with this one.
    Although, the Ridley doesn't technically have "gears"
  7. jethro911
    jethro911 Member
    Technically it does have gears but they don't shift as the clutches do all the work. I'm interested to see what the real answer is!
  8. donald branscom
    Guerneville CA
    If you could just google it that would be no fun.
  9. donald branscom
    Guerneville CA
  10. donald branscom
    Guerneville CA
    ANSWER:
    The motorcycle was a HODAKA. IT was designed by Pabtaco Hodaka.
    He died on a HODAKA in a intersection in Japan on a HODAKA.
    The HODAKA had gears and A rod went through the trans that would allow steel balls to fall into spaces between the gears that would lock them into place. If I remember correctly there were 20 steel balls about 1/4 inch diameter,
    It was very simple and the transmission shifted smooth as glass and you could just about not even have to use the clutch.
    I will try a VFR/VF question next time.
  11. Cundalini
    Cundalini New Member
    Sacramento CA
    Wait I got it. Its a HODAKA!
  12. BWeiss
    BWeiss Johnny Partseed
    Rancho Cordova, Ca
    ^^^^^ nice try....but...
  13. daveyto
    daveyto New Member
    Scarborough, Canada
    The chopper is kind of cool...Wonder what they cost?
  14. daveyto
    daveyto New Member
    Scarborough, Canada
    PAB TACO?
    Sure he wasn't Mexican?
    OK..I know it was politically incorrect. Apologies to all the Mexican, TEX Mex, And Mexican Americans.
    Hate me!!! I don't care anymore!!!
