Trim Cliips - Source or Substitute?
Discussion in 'Mechanics Garage' started by Kiowa, Feb 25, 2007.
  1. Kiowa
    Kiowa New Member
    West Texas
    This is a small and insignificant subject but an irritating one. The cowling trim clips seem impossible to remove without breaking or distorting them. I guess I don't have the knack of finding the little center section of the plastic part that has to be raised without damaging it.
    So, does anyone know of a cheap source for these trim clips, or, better yet, a substitute clip that is easier to remove? The best price I can find for ten (with shipping) is $30 which seems exorbitant to me.
    In previewing this post it occurred to me that the term "trim clip" could have a double meaning. I'm not that clever or funny and I'm just inquiring about the fragile little black plastic part. I know about the Saturn clips and the GM clips are too large for my '06.
  2. rode2rouen
    rode2rouen Guest
    The problem may be your removal technique.....the center section is to be pushed IN for removal.
    Rex
  3. Action
    Action New Member
    Albuquerque
  4. Spike
    Spike New Member
    I find them as annoying as hell, and would rather they use a screw/bolt instead. Or a Dsuz fastners.
  5. RVFR
    Was going to say the same thing...
    also agree with Spike, dsuz does it for me
  6. seadooloo
    seadooloo New Member
    New Baltimore, Michigan
    I use the technique that rode2rouen shows in the diagram and still have all the original trim clips on my 2002 that I have had since August of 02. Not bragging or anything, I just find that they are pretty durable when you use the correct technique. Push the center in, then pull the clip out. After that you have to spread open the tabs to get the center to go back out, past flush, then once inserted push the top flush and it will hold until you push the center in again for removal.
  7. grinder
    grinder New Member
    British Columbia, Canada
    I just removed my side panel for an oil change. 05 model. I had no problems with the clips. I used a small allen key to push the centre in. Sometimes you need to wiggle the panel a little as it may be pressing on the side of the clip and jambing it. I managed to get all the clips out and reinstalled without any damage. Just be patent and gentle. If it doesn't come out easy something is jambing it. Seadooloo's technique I found to be spot on.
  8. Kiowa
    Kiowa New Member
    West Texas
    Rex,
    Oh . . . I was trying to remove them like GM trim clips. I will have to give them another chance. Thanks for all the informative replies.
  9. rode2rouen
    rode2rouen Guest
    I only trashed 4 of the little buggers before my Ebay shop manual showed up!!!
    It's kinda stoopid of Honda to not put the trim clip "operating instructions" in the Owner's Manual!
    Rex
  10. reg71
    Sikeston, MO
    I actually bought the ones Action linked to but haven't installed them. On my next oild change or other maint, I'll be switching out, and I have a whole bag of them so I dont have to be careful with the damn things.
  11. walshie
    walshie New Member
    So Cal
    This diagram should be on the home page. Broke 3 before i figured out how to remove them and then couldn't figure out how to insall without finding this in a search. Thanks for posting. Seriously this should be pinned in maintenance.
  12. 34468 Randy
  13. Metallican525
    Metallican525 New Member
    Rockville, Maryland
