Top end oiling issues for vf500
Discussion in '1st & 2nd Generation 1983-1989' started by Lamber, Aug 15, 2012.
  1. Lamber
    Lamber New Member
    I have seen it mentioned that all interceptors from '83 to '85 (and possible '86) have problems with top end oiling and therefore premature and severe cam wear. I have't been able to find a definitive thread about this problem for vf500's (please tell if there is one so I don't make a redundant thread).
    I want to find out if there's anyone who has found a decent solution to this problem (if in fact it does exist for vf500's). Has anyone done anything like adding new oil lines to the problem area, etc.?
    Thanks!
  2. tinkerinWstuff
    There is no definitive thread and the issue is still hotly debated.
    Most people with any authority on the issue contend that there is no oiling issue and that the problem is materials and poor maintenance. Adding more oil just puts a bandaid on the real problem while robbing the lower end of badly needed oil. Some will claim that there is poor flow at idle RPM but thus far it's all internet rumor with no definitive proof, i.e. someone who's been able to measure flow or video a running engine with no flow. People see cam wear and assume it's due to lack of lubrication.
    With good maintenance and frequent oil changes, there is no need to change the oiling system. The bigger issue is valve stems and valve springs which also had problems, parts no longer available, and no good fix.
  3. stewartj239
    stewartj239 Member
    Syracuse, NY
    I went through this almost 10 years ago and turned up no solid proof that the 500 suffered the same problem as the 1st Gen 700 and 750. Even so, I still put a top end oiling kit on my 500 and to this day have had no issues. In addition, my brother also has an '86 500 with 35K miles and no kit, and he has no issues either.
  4. Lamber
    Lamber New Member
    What is the top end oiling kit? Did you make it custom or is there a preferred design/kit already out there?
    and thanks tinker, I'll be sure to keep up with the maintenance
  5. stewartj239
    stewartj239 Member
    Syracuse, NY
    Mine was a bolt on kit. It replaces the stock oil lines to the top end. This kit runs oil from the filter to the top end. I've included some photos. There are other kits out there that require drilling and tapping as well.
    VF500F Top End Oiling Kit - 3.jpg VF500F Top End Oiling Kit - 2.jpg VF500F Top End Oiling Kit - 1.jpg
  6. tinkerinWstuff
    They are no longer made - and are pointless.
  7. stewartj239
    stewartj239 Member
    Syracuse, NY
    For the 500, I don't think it is necessary. If I could do it over again, I would have saved the money and not installed it, but I also don't think there is any harm in having it either.
  8. commrad
    commrad New Member
    Red Hill, GA
    I rode my v45 magna like I stole it for 10's of thousands of miles and the cams looked new when I parked it. They are the main culprit of toasting cams. A local Honda guru (yeah he is that good, retired now) told me in the 808's to keep it over 3k rpm and it would be ok. I watched dozens of them come in for repair hanging out at the shop but mine kept running until the day I sold it with out issue. The 500 doesn't have anywhere near the bottom end torque of the 750 so I think one of the reasons they never gave the cam problems as bad was because it was just more natural to keep the tach on the north end of the scale.
  9. karl61
    karl61 New Member
    I recently emailed dave dodge regarding his oil modification kit and he responded: He is selling them for 269.00. On his website it indicates that the kit is not recommended for the 500.
