Tire Patch Kit
Discussion in 'Gear & Accessories' started by ZonaMan, Apr 14, 2009.
  1. ZonaMan
    ZonaMan New Member
    Tucson
    I have been wanting to get one of these kits for some time now especially for rides when I am very far away from home, however I found that MC specific kits were typically $60 - $120.
    Today while buying some Mobil 1 and a new filter at the corner auto parts store, I thought I'd check to see if they have a patch kit. Yes they do and for only $20.
    It's marketed as an ATV tire patch kit, but I don't see how it wouldn't work on a mc tire. For your reference, it's Brand is Victor under Bell auto products.
    I hope this helps some of you save some money and be better prepared for a long distance ride. I am getting tired of companies marketing MC specific items at inflated prices.
  2. Craig in Alabama
    Craig in Alabama New Member
    Madison, AL
    Flats
    I had a flat rear tire on my Buell last week while I was at work. Luckily I had a Monkey Grip plug kit from Wal-Mart (~$4.00) and some CO2 cartridges in my luggage. Pulled out a big ole drywall screw, plugged it and put 5 cartridges of air in it. Enough to get to a compressor. I also carry a can of fix-a-flat just in case, but didn't have to use it. The rear tire hasn't lost any air so far and I think I'll get to use it until I hit the wear bars.
    BTW, while I was at Wal-Mart to replenish my CO2 supply, I picked up a little 12v air pump that they had on sale for $4 (from $10). The Ulysses has two
    12v sockets on it. So now I've got that and I just put my extra CO2s on the viffer. If you take those little pumps out of the decorative plastic they hardly take up any space.
    Cheers!
    Craig :smile:
  3. Hotbrakes
    Hotbrakes New Member
    Richmond, VA
    Plug kits should never cost more than $5. Walmart has kits with small compressors as mentioned above pretty cheap too. I always carry mine when I go far from home. And I don't typically throw a rear tire out that has been patched. Front? Yeah.
  4. ZonaMan
    ZonaMan New Member
    Tucson
    I will check walmart for these other kits and may return the one I bought! TY
