Tip over sensor 2003 VFR 800
Discussion in 'Mechanics Garage' started by Cstack, Jul 11, 2014.
  1. Cstack
    Cstack New Member
    Can anyone tell me where the tip over sensor is located on a 2003 vfr 800? It was knocked over and now won't start. Turns over but just doesn't fire up. Never had any issues until it was knocked over. Thanks
  2. Scubalong
    Check the kill switch on the side stand and on the throttle controll
  3. MrSleep
    MrSleep New Member
    Verdigris, Oklahoma
    The bank angle sensor is between the gages and the headlights. As suggested by Scuba, flip the kill switch back and forth a few times. Seems to be a common vfr problem.
  4. jethro911
    jethro911 Member
    Merrickville, Ontario Canada
    See the black sensor with the red wire? That's it.
  5. ridervfr
    Belgium
    You can re-set the sensor by rocking the kill switch after it falls over? Sucks if you have to peel all that body work off to access bank angle sensor. I was working on a TL1000R and the sensor was right near the gas tank, very easy to access, same symptom as yours, it would crank, start for a second or so and then die. Turned oot that it was up-side down, dirty rotten bastards. Happy ending to story, as bike rode good. Anyway, good luck, don't tip over any more and keep the shiny side up. :thumbsup:
  6. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    Here is how you bypass it to rule out the bank angle sensor.[​IMG][​IMG][​IMG]
    Don't ask why I know this... Lol
  7. Voided76
    Voided76 New Member
    San Diego, CA
    I'm guessing this was shedding weight in the name of science? heh.
  8. ridervfr
    Belgium
    When I was around a turbo busa that was drag raced, they used to take apart the switch and silicone the ball that resides in there. The problem was, those bikes launched so hard from the line, that they were being killed by the "bank angle sensor/tip over switch." Far as shedding weight, you could always take a good "pooh" before heading oot onto the race track, good for a few less pounds :bs: yuk...
  9. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    I like doing wheelies.... :(
    Yes I know, I am a squid and deserve to be flamed now.
  10. Voided76
    Voided76 New Member
    San Diego, CA
    I lurve wheelies. I just have never tagged the sensor and had it stall down on me... ...on this bike...
    yet...
    >_>
  11. mneal
    mneal New Member
    I may have a band bank sensor, bike just shit off and no fuel pump whine when turn the key. What pins did you jumper?
    QUOTE=CandyRedRC46;447635]Here is how you bypass it to rule out the bank angle sensor.[​IMG][​IMG][​IMG]
    Sent from my iPhone using Tapatalk[/QUOTE]
  12. MrSleep
    MrSleep New Member
    Verdigris, Oklahoma
