Tight chain link
Discussion in '1st & 2nd Generation 1983-1989' started by JerryIke, May 8, 2017.
  1. JerryIke
    JerryIke New Member
    So I put a new chain on. My chain tool broke before getting the link to flare like it was supposed to. I had one of the "clip links" so decided to put that on. The link went in tight. Now I see the link stays in a "kinked" position. Will use take care of this problem or should I try a different solution/link? This is my first chain drive bike since the 70's so I'm a little unsure.
  2. James Bond
    James Bond Member
    Dixie
    I would take the get another link and flare it correctly for peace of mind.
  3. Gator
    Gator Member
    I have seen flared links kink but never a clip link. I would put in a new link and correctly flare it.
  4. jeremyr62
    jeremyr62 New Member
    Ireland
    Limerick, Ireland
    Chains, brakes and tyres deserve respect. I would get another soft link too and flare the rivets properly.
  5. JIMLARCH
    JIMLARCH New Member
    Ontario, Canada
    Put the proper link on. That is obviously not the correct one or it would fit properly.
  6. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    Same brand clip link as the chain? Or generic you had lying around? If it was tight before you put the side links on I would change it for sure.
  7. JerryIke
    JerryIke New Member
    It was a generic I bought from DK. I'll try the original link and see if I can't round a chain tool.
    Thanks guys.
