There must be a trick to it. Rear sprocket carrier
Discussion in 'Mechanics Garage' started by 7zark7, Mar 18, 2008.
  1. 7zark7
    7zark7 New Member
    How do i get this thing off? I have the 46mm nut and the washer off but I can't get the sprocket carrier seperated from the swingarm. What am I doing wrong? Should I heat it up? I don't want to ruin the rubbers or bearings or seals.
    HELP!
  2. mello dude
    Romania
    Dude - can u post a pic of where you are at? I think I did the same thing but dont remember it being that hard.
    MD
  3. hondawolf
    hondawolf New Member
    Livermore, Ca
    Did you loosen the pinch bolt on the back of the swing arm? Can't remember for sure, but might have to loosen it first....
  4. Mac
    Mac New Member
    NC High Country
    Whack it with a rubber mallet.
    Mac
  5. RVFR
    Sounds like you need to get a bigger hammer, actually I'm no help, never had one apart, If I may be so bold to ask, Why you're needing it off?
  6. 7zark7
    7zark7 New Member
    I think I do. It should just slide off according to the manual (at least thats what it looks like) I need to get it off because I have to put it in another swingarm. Long story.
  7. 7zark7
    7zark7 New Member
    After reapeted blows with a hammer and a block of wood, I finally got it off. Time for a very thorough cleaning and some anti seize.
  8. Big3
    Big3 New Member
    Lancaster, Ohio
    this we gotta hear ............
  9. 7zark7
    7zark7 New Member
    Well, it's not actually that long of a story. I have an 02 SV650 and I want to install a VFR wingarm on it. I bought a completer 94-97 swingarm and wheel a few years ago in preparation for this mod. Recently I found out tat the 90-93 swingarm works much better for this so I was able to find just the swingarrm without the hub. So here I am, I need to get the hub off of the 94-97 and installed on the 90-93 so I can start fabing this thing up.
  10. VT Viffer
    VT Viffer New Member
    South Carolina
    I hope that 90-93 and 94-97 are the same part, for your sake...:frown:
