The Fi lights when riding on bumpi roads
Discussion in '5th Generation 1998-2001' started by Drummer, Jul 1, 2007.
  1. Drummer
    Drummer New Member
    Romania - Bucharest
    i have a problem with my vfr since the moment i bought it! when i ride it on bad roads sometimes the moment it "jumps" the Fi lights for 2or 3 seconds and the engine looses power.After that in comes back to normal.
    that's one problem. another one it's the low beam. sometimes it's not working. if i turn on the hight beam and then return to low beam it works.
    do you have any ideea why is that happening?
  2. Wu-Viffer
    Wu-Viffer New Member
    San Francisco, CA
    I had a similar problem, it was a loose groud connection with the battery. Check it out.
    Mel
  3. John451
    John451 Member
    My suggestion also, saw a VFR with a similare issue last weekend, ended up being a loose Ground cable.
  4. Drummer
    Drummer New Member
    Romania - Bucharest
    thank you very much! is there a particular place where i should look for the loose ground cable ? ...so i can go directly to the source?
  5. John451
    John451 Member
    Try this link from UK's VFR site it details " FI light " trouble shooting and shows photos of the Earth Block location.
    http://www.bikersoracle.com/vfr/forum/showthread.php?t=76161
    If memory serves there is another earth lead connected to the frame beneath the right side fairing that you could check as well.
